Hi to all,
I have four units of the HPE 2530-48G switch. These switches are connected in a ring between them for redundancy purposes. These are configured as a switch stack (one commander and three memebers in the stack)
In the units 2 and 4, I have got configured four trunks in each switch with two ports each. In the trunk ports, I have got connected access points which let us to access to the WIFI network.
When I try yo ping to IP address of this WIFI network, I loose a lot of packets and the users can't to work cause the applications can't not establish the comunication (they can't map units pe)....
I have configured the trunks with this configuration:
trunk 39-40 trk1 trunk
trunk 41-42 trk2 trunk
trunk 43-44 trk3 trunk
trunk 45-46 trk4 trunk
vlan XX
name "XXX"
untagged Trk1-Trk4
tagged 47-48
no ip address
exit
vlan XX
name "XXX"
tagged 47-48,Trk1-Trk4
no ip address
exit
vlan XX
name "XXX"
no ip address
exit
vlan XX
name "XXX"
no ip address
exit
spanning-tree
spanning-tree Trk1 admin-edge-port
spanning-tree Trk1 priority 4
spanning-tree Trk2 admin-edge-port
spanning-tree Trk2 priority 4
spanning-tree Trk3 admin-edge-port
spanning-tree Trk3 priority 4
spanning-tree Trk4 admin-edge-port
spanning-tree Trk4 priority 4
spanning-tree instance ist Trk1 path-cost 20000
spanning-tree instance ist Trk2 path-cost 20000
spanning-tree instance ist Trk3 path-cost 20000
spanning-tree instance ist Trk4 path-cost 20000
spanning-tree priority 4
trunk-load-balance L2-based
Is correct this configuration?? Is there any mistake which can be breaking the communication?? The trunks aren't LACP trunks.
Thanks in advance.
Kind Regards.
David.
#2530-48G#trunks#spanning-tree#STP
