Hi All,
I wanted to ask if any of you had a strange behaviour of WiFi when WPA2 used on Windows Clients?. We have MM-MD setup, luckily not in production yet. Problem I have is that I have pretty much vanila config, just setup Cluster, VRRD on MM and MD's. From that perspective all looks good, cluster is L2 and Loadbalance of AP and Users works.
Here is the issue, I've setup tunneled SSID using WPA2-AES and only smarthphones can connect without any issue.
When I try my win10 laptop or on clients Win10 pro laptops we have problems to associate to the SSID. All laptops up to date (including WLAN drivers, which are btw also different makes). Most of the AP's are Ap515 but we have for testing setup AP303 with same results. Windows machines can see the SSID but fail to connect.
If I setup open SSID all works no problem. Debug shows "wrong replay counter". I've contacted support, we have tried the known stuff (Increase WPA timers, power settings, disabled 80MHz and few other bits) but so far we have no fix. Did anybody experience similar on their setup?
Version of code tried: 8.6.0.0 and 8.6.0.4
2 VMM+ 2 7210's.
Any hints would be greatly appreciated.
