It is possible to terminate a rap in a local controller and how?
  • 1.  It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 01:34 PM
    It is possible?
    If its how you configure it?
    I have always configured this to point it to the master controller.
    In this case i got a master in one country and a local controller on another country.
    The client wants to terminate their remote APS on their local controller.
  • 2.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 01:38 PM
    You have to create a 1:1 nat from a public  address to the private address of the local controller.
  • 3.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 02:32 PM
    looks like the same to me(at least that part)
    I mean i do that for the master controller when i configure it(the one on one Nat from public)
    But what about the vpn services? is that config local to the controller? or i configure that on the master controller?, you know i have to configure the address pool for those raps
    And what about the whitelist of the raps? do i just configure them on the master controller? does it share that list with the local controller ?  or i have to configure that  list on the local controller itselft
  • 4.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 03:09 PM
    The pool is local to the controller.  The whitelist is stored on the master by default.
  • 5.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 04:24 PM
    So basically is the same?
    1-You configure the pool on the Local controller under the VPN services
    2-You configure the whitelist on the master
    3-we create the 1on1 nat to the controller ip adddress
    4-Create a group for that rap
    5-Assign the Virtual AP of the corporate SSID that we already have on the corportate to that RAP group
    6-Provision the RAP pointing it to the public ip address that we are assigning it on the 1on1  nat .
    i am missing something?
    We just want the SSID of the corporate on the remote site.
  • 6.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 05:17 PM
    That is all you need to do.  Make sure that there is no lms-ip in the AP system profile for that ap-group.
  • 7.  RE: It is possible to terminate a rap in a local controller and how?
    Posted Mar 18, 2020 05:19 PM
    Thanks!!!!
