Comware
J8697A - HP5406zl firmware question
  • 1.  J8697A - HP5406zl firmware question
    Posted Mar 27, 2024 09:18 AM
    Hi to all, i have some J8697A switches.. as i found these should be EOL since 2020 or earlier but if i am searching right i can find firmware patches up to 10/2022... I am just wondering if they are applicable to my devices... I am finding them here https://networkingsupport.hpe.com/downloads;search=J8697A but i am also wondering what are the differences between K & KA versions... My switches are at K.16.02.0026 and boot rom K.15.30. Can i flash KA.16.04.0026? Any advice would be appreciated!
    Thanks in advance,
    George
  • 2.  RE: J8697A - HP5406zl firmware question
    Posted Mar 28, 2024 04:02 AM
    Hi, for the 5400zl series the latest release is K.16.02.0036 released Oct 11, 2022
    I think the search system is wrong, suggesting that the KA.16.04 branch is for:
    But the release notes confirm it is just the 3800:
  • 3.  RE: J8697A - HP5406zl firmware question
    Posted Mar 28, 2024 04:06 AM
    Thank you very much for the confirmation.. This is what i was thinking of...
