I've figured out the sntp error.
sntp means simple network time protocol.
The 1810 says the date is dec 31, 1969
I enabled snmp, hoping to set the date on the 1810, and influence the firmware update, but no luck.
Disabling sntp makes the errno365 go away.
I'm trying to upgrade the firmware on the 1810 from p.1.6 to p.1.17.
Using the web interface SW, Maintenance\Update_Manager, update_method=http, browse_for_file=p1.17.stk, update_type=code, image=backup, (press download)
pops-up a window that says Warning: The data transferwill take few minutes ...(click OK)
pops-up another window that says 1) make sure the image transfer was successful,... (press enter)
pops-up a Transfer_Status window, with progress indicators,
Then the web interface blinks, and I'm at the login screen.
But also sometimes, my laptop nic pops-up a window that says, network cable unplugged ( which is wrong) and the web interface says "The page cannot be displayed
The status\logfile is empty, no indication of a file transfer.
What do I do?
