Anyone have experience integrating JAMF with CPPM? We're seeing an odd situation which happened again.
In CPPM, we configure the JAMF server and life is good. CPPM logs indicate it is communicating properly with JAMF and getting updates.
What we find is at some point, devices which are added to JAMF come over to CPPM but none of the JAMF information is in the endpoint database. As a result, CPPM indicates the device is not in JAMF (it is there) so the device gets assigned a BYOD type role. When this happened before, we deleted the JAMF server connection info and added it back then the endpoint database populated correctly. Do I have to do this periodically to get JAMF to work properly with CPPM?
