Hello there..
We've been using Jamf Pro as just a context server. It's been working properly until recently. My understanding is once they stopped allowing basic user authentication, you could enable bearer token authentication to continue using the user account in Jamf.
But, enabling this, results in several error messages per SECOND showing under Events:
"Failed to fetch Endpoint details from jss.pds.org Error code: 401 Verify Proxy settings, Server credentials and retry."
Have a case with TAC, but the first thing they said is that Clearpass doesn't support OAUTH authentication, even though this is an option - TAC first line of support recently leaves a lot to be desired to be honest..
Any ideas?
