Regarding TAA Compliance read, as example, here (more if you do a generic search through Internet).
Probably if your environment requires a fully TAA Compliant Switch (Firmware included) I guess you have to use the TAA tagged one, if your environment doesn't require a fully TAA Compliant Switch (as example, Firmware excluded from being TAA tagged) then you can install whatever Firmware your Switch supports.
