Set the IP and protcol and prepare your "server" with tftp server or ftp server, then fetch the firmware "<2> Update Main Application File"
Original Message:
Sent: Oct 28, 2024 03:10 PM
Subject: JG913A Firmware
Hello Zac67,
As you can see this is the menu I am getting in, check image below. The ethernet submenu is a death end. The only I can do there is set the TFTP or FTP configuration.
On TFTP config just ask for my TFTP server settings and the soposed switch IP.
The local IP is what I desire the swith IP should be. but this is not right. The switch continue with no IP address.
Please advice if you any other though.
Kind Regards
Original Message:
Sent: Oct 28, 2024 05:25 AM
If you're using the serial console you should configure the basic IP parameters to enable the web management interface, likely in the Ethernet submenu.
Original Message:
Sent: Oct 25, 2024 04:04 PM
Hello Zac67,
I have the same issue. I got the lastest firmaware for the HPE switch. But, my problem is that my coworker deleted the file configuration. no the storage is flash. My question is how I can upload the firmaware to the switch. I tried TFTP using the console connection, didn't work because the swith has no IP address; I cannot upload on the web gui iether for the same reason no IP address on the switch.
Could please help me to find the way to do it. I believe there is a way to do it.
Kind regards
Original Message:
Sent: May 07, 2024 04:47 PM
Try https://networkingsupport.hpe.com/downloads;pageSize=25;search=JG913A;sort=VERSION_DESC;fileTypes=SOFTWARE
Original Message:
Sent: May 04, 2024 01:26 AM
I have a 1620 JG913A switch, when I select boot system it will show boot failed it says
Starting to get the main application file--flash:/jg913a-cmw520-r1108.bin!
The main application file does not exist--flash:/jg913a-cmw520-r1108.bin!
Starting to get the backup application
file--flash:/JG913A-CMW520-R1103_bak.bin!
The backup application file does not
exist--flash:/JG913A-CMW520-R1103_bak.bin!
Starting to get the secure application file--flash:/secure.bin!
The secure application file does not exist--flash:/secure.bin!
Boot App fails!
where can I download the JG913A firmware ?
