Comware
JG925A 1121 firmware
This thread has been viewed 63 times
  • 1.  JG925A 1121 firmware
    Posted Feb 06, 2023 09:51 AM
    I tried to find 1121 firmware for JG925A (HP 1920-24G-PoE+ (180W)) but I didn't found it. Do you have link for it or is there 1121 firmware for JG925A at all ?
  • 2.  RE: JG925A 1121 firmware
    Posted Feb 06, 2023 03:51 PM
    Due to some reason the file is not on the ASP portal. I've shared it to you here:
    Drop Box Host:    hprc-h2.it.hpe.com  (16.230.110.42, Failover: 16.228.110.42)
    Login: fw1920
    Password: xh$RM5np=BQ6bh+R
    The link will be valid 7 days.
    Ivan Bondar
  • 3.  RE: JG925A 1121 firmware
    Posted Feb 07, 2023 02:54 AM
    TimoH
  • 4.  RE: JG925A 1121 firmware
    Posted Aug 28, 2023 02:25 PM
    I am also searching for the 5.20.R1121 firmware for my JG925A. Could you provide it to me as well, since the link has already expired?
    Thanks.
  • 5.  RE: JG925A 1121 firmware
    Posted Dec 11, 2023 11:56 AM
    Hello Ivan,
    I'm also looking for  JG925A firmware ver.5.20.R1121. The link above has been failed.
    Is it possible to upload again?
    Thank you for your help.
  • 6.  RE: JG925A 1121 firmware
    Posted Feb 26, 2024 10:59 AM
    Hello Dear ,,
    Iam looking for  JG925A firmware ver.5.20.R1121. I searched all google but cant find anything !
    Is it possible to upload again, Plz ?
    Thanks in Advance
  • 7.  RE: JG925A 1121 firmware
    Posted May 28, 2024 06:56 AM
    Heyy Could be please send it again!! It would be really helpful, Thank youuu
  • 8.  RE: JG925A 1121 firmware
    Posted May 28, 2024 07:32 AM
    Sorry but not correct file.?? I need Firmware fro J9021A 2810-24G
  • 9.  RE: JG925A 1121 firmware
    Posted Jul 05, 2024 10:58 AM
    Hi Ivan
    Are you able to share the file with me please. Your help would be much appreciated :)
    Remi
    We had power outages and the bin files are now corrupt as the files are there but the system errors out with:
    Starting to get the main application file--flash:/JG925A-CMW520-R1110.bin!
    The main application file does not exist--flash:/JG925A-CMW520-R1110.bin!
    Starting to get the backup application
    file--flash:/JG925A-CMW520-R1110_bak.bin!
    The backup application file does not
    exist--flash:/JG925A-CMW520-R1110_bak.bin!
    Starting to get the secure application file--flash:/secure.bin!
    The secure application file does not exist--flash:/secure.bin!
    Booting App fails!
