Aruba Central
JSON Files
  • 1.  JSON Files
    Posted Nov 01, 2022 01:38 PM
    I am managing a 2930F switch through Aruba central.
    However, we do not know the equivalent  syntax command to enter in the json file that corresponds to the network command.
    Can anyone assist?
  • 2.  RE: JSON Files
    MVP GURU
    Posted Nov 01, 2022 03:17 PM
    Can you add some more context to this please? Are you talking about the JSON variables file which is used with template based configuration?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: JSON Files
    Posted Nov 02, 2022 11:14 PM
    Yes I am talking about the JSON file.
    But not just changing of variables.
    If I need to type in new commands into new switch, how do I know what to input into the json file.
    E.g. tyoe in "ip dhcp" in switch, how do I know what syntax to key in for JSON file?
