Wired Intelligent Edge
This thread has been viewed 31 times
  • 1.  Jumbo Frame
    Posted Aug 10, 2022 06:49 AM
    HW INFO:
    -Fortigate 60F
    -Aruba CX6100
    -Aruba AP-515
    All VLAN gateways is forti.
    Forti also handle dhcp server
    AP, Switch and Forti in the same location
    https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedAttachments2/D536B1B7-758C-4B2B-8C67-F355C2B097B9-2-Aruba%20WiFi6%20Networks%20Deployment%20Guide%20(1).pdf
    According to that, I need to enable jumbo in the switch and router
    1. pdf said need to enable jumbo frame end-to-end
    it said enable in Switch and Router
    I believe in my case ROUTER=FIREWALL Forti
    do I need to enable Jumbo in the AP as well
    2. In the switch side. Do I need to enable jumbo per port that connected to AP or GLOBAL (ALL ports)
    tq
  • 2.  RE: Jumbo Frame
    Posted Aug 10, 2022 08:18 AM
    That Jumbo frame recommendation is mostly related to controller APs that tunnel the traffic; and the end-to-end related to the AP, controller, and all switches in between.
    You can't enable jumbo on the internet, so wouldn't bother too much in this case.
