Network Management
last person joined: 9 hours ago
Juniper WLA-321 AP can manage on Airwave ?
  • 1.  Juniper WLA-321 AP can manage on Airwave ?
    Posted Jul 16, 2014 03:25 AM
    Hi All,
       WLA-321 AP can manage on Airwave via snmp on airwave ? From searching  we found that  WLC 880 controller and Ring Master (Software management ) are supported snmp but not sure WLA-321, Is it support  read and write mode via snmp ?
  • 2.  RE: Juniper WLA-321 AP can manage on Airwave ?
    Posted Jul 16, 2014 01:24 PM
    The WLA-321 is a Thin AP and doesn't support direct management.
    Best bet is to load the WLC800 MIB for the controller and manage it via that.
    Ewan
  • 3.  RE: Juniper WLA-321 AP can manage on Airwave ?
    Posted Jul 17, 2014 12:16 AM
    Luckily there isn't a huge amount of functional changes from the models that Airwave supports to the 321.  That said, we tested Airwave out on our current Juniper wifi infrastructure, and it's definitely got some glitches.  Controller clusters in particular seemed to confuse the hecke out of Airwave.
    With the recent partnership announced between Juniper and Aruba, however, they have at least commited to cross platform monitoring, so in the nearish future you should be able to use Airwave for your day to day troubleshooting and monitoring.  For now, though, I'd plan on sticking with either managing the Juniper directly or via Ringmaster.
  • 4.  RE: Juniper WLA-321 AP can manage on Airwave ?
    Posted Jul 17, 2014 07:12 PM
    The cluster visibility issues are expected to fixed in Airwave 8.1
