Juniper WLC WebAuth - Guest Access
  • 1.  Juniper WLC WebAuth - Guest Access
    Posted Feb 20, 2018 12:03 PM
    Hi Guys,
    Does anyone have any experience with using Juniper/Trapeze WLC with Aruba Clear Pass Guest captive portal?
    We followed the KB article on the Juniper website;
    https://kb.juniper.net/InfoCenter/index?page=content&id=KB32116&cat=PRODUCT&actp=LIST&showDraft=false
    We're seeing the WebAuth take place with an accept in the access tracker however the guest client is directed back to the registration form as opposed to being accepted and allowed access.
    Following this we see an additional entry in access tracker with MAC Authentication failing on the following error;
    Error Code: 209
    Error Category: Authentication failure
    Error Message: No password in request
    RADIUS MAC-AUTH: Password in request doesn't match username. Not attempting MAC authentication
    Cannot select appropriate authentication method
    Any input would be greatly appreciated.
    Thanks in advance!
  • 2.  RE: Juniper WLC WebAuth - Guest Access
    Posted Feb 20, 2018 04:39 PM
    Have you tried using EAP-MD5 ?
    Pardon typos sent from Mobile
  • 3.  RE: Juniper WLC WebAuth - Guest Access
    Posted Feb 21, 2018 03:03 AM
    Yes, I read that on the forum elsewhere.
    Our Juniper service inlcudes EAP MD5 as an Authentication Method.
  • 4.  RE: Juniper WLC WebAuth - Guest Access
    Posted Feb 21, 2018 03:16 AM
    This post looks related. Have you tried that?
  • 5.  RE: Juniper WLC WebAuth - Guest Access
    Posted Feb 21, 2018 04:05 AM
    Yes, I saw that also, I have imported the XML file as an authentication method, here's whats on our service;
    Authentication Sources:
    1. Juniper MAC Auth [Generic SQL DB]
    2. [Guest User Repository] [Local SQL DB]
    3. [Guest Device Repository] [Local SQL DB]
    4. [Endpoints Repository] [Local SQL DB]
    Unfortunately this didn't seem to make any difference.
  • 6.  RE: Juniper WLC WebAuth - Guest Access
    Posted Feb 21, 2018 04:08 AM
    Please work with Aruba TAC as it looks like it is a small detail that prevents your solution form working.
