hi, does anyone know why this error is coming up on the msm 710 access controller. if anyone can point out the reason and help to solve this issue, it would be great.
thanks
HP support keeps telling me it is due to the amount of usage on the device... basically the Web Server on the MSM710 is failing and auto restarts...
Last suggestion from them was an update to beta code but still no fix...
Are you using FireFox to connect? I have found that the webserver on the controllers crashes from time to time when i connect with firefox. Using IE it seems to work reliably. I found an article about this somewhere, but I cant remember where. From what I remember, HP is blaming some update in the newer versions of FireFox for this behavior.
