Keeping Instant AP up without an uplink
  • 1.  Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 12:32 PM
    I'm trying to use an Instant AP to measure RSSI/SNR for surveying purposes. We used to use a campus AP with a "backup" SSID that would always be up. Is there a way of keeping the Instant AP up and broadcasting the SSID even when there is no link to the Ethernet port? (Right now, I have a battery that supplies POE, but being a battery, there's no interface link.)
    I appreciate any insight on this. Thanks!
  • 2.  RE: Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 12:37 PM
    Go to System > Uplink > Enforce Uplink: Ethernet
  • 3.  RE: Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 03:14 PM
    Already did that. My configuration is identical to your screen shot, Tim. It still reboots.
    I also do already have it set to "Can be used without uplink". Still no dice.
  • 4.  RE: Keeping Instant AP up without an uplink
    Posted Apr 02, 2014 03:22 AM
    Can you try giving the AP a static address with the setenv commands?
    Sent from Windows Mail
  • 5.  RE: Keeping Instant AP up without an uplink
    Posted Apr 02, 2014 09:42 AM
    My issue was not putting the ap in standalone mode.
  • 6.  RE: Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 03:41 PM
    Here's some pertinent parts of the (re)boot messages:
    Ethernet uplink not active yet
    *snip*
    *snip*
    Got all network params from APboot env. Skipping[   43.551940] bonding: bond0: releasing backup interface eth1
     DHCP
    [   43.644760] ethernet_device_event: dev eth1 is down
    10.0.0.1 255.255.255.0 10.0.0.1
    *snip*
    AP rebooted Thu Jan 1 00:07:42 UTC 1970; Gateway unreachable
     Here's items from my config:
    survey-ap225# sho uplink status
    Uplink preemption             :disable
    Uplink enforce                :eth0
    Ethernet uplink eth0        :DHCP
    Uplink Table
    Type      State  Priority  In Use
    eth0      DOWN   0         Yes
    Wifi-sta  INIT   6         No
    3G/4G     INIT   7         No
    Internet failover             :disable
    Max allowed test packet loss  :10
    Secs between test packets     :30
    VPN failover timeout (secs)   :180
    Internet check timeout (secs) :10
    ICMP pkt sent        :0
    ICMP pkt lost        :0
    Continuous pkt lost  :0
    VPN down time        :0
    survey-ap225# sho uplink config
    survey-ap225# sho ip int brief
    Interface                   IP Address / IP Netmask            Admin   Protocol
    br0                         10.0.0.1 / 255.255.255.0           up      up
    survey-ap225# sho ip route
    Kernel IP routing table
    Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
    10.0.0.0        0.0.0.0         255.255.255.0   U         0 0          0 br0
    172.31.98.0     0.0.0.0         255.255.254.0   U         0 0          0 br0
    0.0.0.0         10.0.0.1        0.0.0.0         UG        0 0          0 br0
    survey-ap225# ping 10.0.0.1
    Press 'q' to abort.
    PING 10.0.0.1 (10.0.0.1): 56 data bytes
    64 bytes from 10.0.0.1: icmp_seq=0 ttl=64 time=0.0 ms
    64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=0.0 ms
    64 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=0.0 ms
    64 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=0.0 ms
    64 bytes from 10.0.0.1: icmp_seq=4 ttl=64 time=0.0 ms
     I appreciate everyone's assistance. I'm not sure why it's saying gateway is unreachable when I can ping it. The issue is that the AP is plugged into a battery that has an RJ-45 port that delivers POE. There's no 802.3 interface or linkstate, so for all intents and purposes, the enet0 on the IAP-225 is down.
    Is there a way to keep the AP up regardless of link state (similar to how a remote AP functions when it loses its uplink with a virtual-ap configured as "backup" or always on)?
  • 7.  RE: Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 04:41 PM
    Ryan,
    Did you convert it to standalone mode first?  Check out the thread post here http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/m-p/57274/highlight/true#M549 by Pmonardo...
  • 8.  RE: Keeping Instant AP up without an uplink
    Posted Mar 24, 2014 09:16 AM
    Thanks, Colin. I overlooked that step. Things seem stable now.
  • 9.  RE: Keeping Instant AP up without an uplink
    Posted Mar 21, 2014 03:09 PM
    Under WLAN Settings, click Show advanced options, select "Can be used without uplink"
