Wired Intelligent Edge
Key Management - License
This thread has been viewed 32 times
  • 1.  Key Management - License
    Posted May 03, 2021 07:29 AM
    I have recently purchased license Aruba Central DM 1 Token 3y Sub E-STU and when I added under key management I got this "Convert DMs to new license types (1)". I don't understand this behavior because I know when I used to add licenses there previously they just popped up without needing to convert them. Now it is showing this and I don´t understand it.
    Please advice, should I do a convert or is it something I have missed?
    nikim ab
  • 2.  RE: Key Management - License
    MVP GURU
    Posted May 03, 2021 08:50 AM
    The license model has changed. See this link: https://help.central.arubanetworks.com/latest/documentation/online_help/content/nms/subscriptions/overview-licensing.htm
    Dustin Burns
  • 3.  RE: Key Management - License
    Posted May 04, 2021 02:10 AM
    You can still buy the "old" licenses for few months and if you need 6300/6400 switch licenses you really should :) "New" 6400 license is something like 20x compared to the DM 1 Token...
    You buy the Token and then convert it to any other license you like. It seems that you can also convert it to gateway foundation licenses too
  • 4.  RE: Key Management - License
    Posted May 04, 2021 04:30 AM
    I see that there are some different foundation licenses for different switch model. I see for example Foundation-Switch-6200/29xx. Does this mean that this license can only be used for 29xx switch models, and if I have for example a switch model 2540 this license wont work?
    nikim ab
  • 5.  RE: Key Management - License
    Posted May 04, 2021 04:37 AM
    Yep you would need "Foundation-Switch-6100/25XX/<16ports" license which is also the cheapest license for switches
  • 6.  RE: Key Management - License
    Posted May 04, 2021 04:46 AM
    Thank you pubjohndoe :)
    nikim ab
