Kick off guest users at midnight
  • 1.  Kick off guest users at midnight
    Posted Sep 10, 2015 08:38 AM
    Currently I have a guest self-reg page that is not available between 00:00-06:00.  This is set in the 'Time-Access' field on the self-reg page.
    I assume this does not actually trigger a CoA and log out the user.
    When the user logs in I want to be able to send back a session timeout of 3 hours or midnight, whichever is the sooner.
    Is this possible and how to achieve it?  I suspect it will mean some custom attribute in the [Time Source] but not familiar with how to do that.
  • 2.  RE: Kick off guest users at midnight
    Posted Sep 10, 2015 09:19 AM
    Yes, you would have to add a new query to the Time Source that essentially subtracts midnight minus now. Then you can use that variable in the session timeout enforcement profile.
    Tim
  • 3.  RE: Kick off guest users at midnight
    Posted Sep 11, 2015 06:01 AM
    Think we are just going to go for a straight session timout of 3 hours instead.
    The quey for seconds until midnight is easy enough.  For other who stumble upon this, the time 00:00 is considered the same day so 'seconds until 00:00' gives erroneous results of tens of thousands of year.  The query needed is 'seconds until 23:59:59'.
    SELECT (EXTRACT (EPOCH from (current_date + time '23:59:59'))::int)-(EXTRACT (EPOCH from now() )::int) as seconds_until_midnight;
