kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
  • 1.  kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 09:47 AM
    kindly the steps how to make it.
    thanks
  • 2.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
  • 3.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 12:36 PM
    I already do this configuration on the s3500
     interface-profile lacp-profile BULDING9
     group id 9
    no interface gigaethernet 0/0/21  #to remove qos profile
    no interface gigaethernet 0/0/22
    on the otherside s1500
     group id 1
    no interface gigaethernet 0/1/0
    no interface gigaethernet 0/1/1
    but the connection down.. any advice
  • 4.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 12:38 PM
    Do you have a switching profile tied to your port-channel?
    Tim
  • 5.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 01:02 PM
    first on s3500 i made lacp between s3500 and milestone server which i have made teaming on it and it success .
    no switching profile i tried
  • 6.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 01:03 PM
    You have to have a switching profile on your port-channel. This is how the VLAN(s) get assigned.
    Tim
  • 7.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
    Posted Sep 08, 2015 01:18 PM
    kindly could you send me the commands to make switching profile
    thanks for your help :)
  • 8.  RE: kindly help i want to make LACP between aruba s3500 and s1500 also between s3500 and s2500.
