known endpoints
This thread has been viewed 36 times
  • 1.  known endpoints
    Posted Aug 01, 2024 04:18 AM
    hi Airheads,
    basic question coming up !!
    in the endpoints repository on Clearpass, the act of making an endpoint known can only be triggered:-
    1. by enforcement policy ?
    2. By manually going into the specific endpoint and changing from unknown (default) to known ?
    thanks
    Peter
  • 2.  RE: known endpoints
    Posted Aug 01, 2024 10:09 AM
    Think you can use the API, and import XML (probably after an export) as well.
  • 3.  RE: known endpoints
    Posted Aug 01, 2024 10:10 AM
     Those are the two usual methods, yes.  Can probably also use API but I've never looked for that.
    Carson Hulcher, ACEX#110
  • 4.  RE: known endpoints
    Posted Aug 01, 2024 10:18 AM
    Edited by Ben_C Aug 01, 2024 10:18 AM
    You can just post the below JSON to the endpoint "/endpoint" for API:
      "mac_address": "00:00:00:00:00:00", - Example MAC
      "status": "Known"
  • 5.  RE: known endpoints
    Posted Aug 01, 2024 10:44 AM
    thanks to all answers coming back,
    because i'm making some policy decisions based on known endpoints i wanted to make sure the defult state is unknown regardless of authentication and that the only way the endpoint known\unknown status can change is by methods i've outlined.
    cheers again
    Peter
  • 6.  RE: known endpoints
    Posted Aug 01, 2024 11:08 AM
    Would not recommend using Known for policy.
    Known vs Unknown has two main purposes:
    1. Filtering for endpoint cleanup
    2. A MAC auth service (not Allow All MAC Auth) - Known is allowed, Unknown is denied
    You should be using some other process/information/tag/etc. for authorization.  If you are needing to authorize specific MAC address, use the Device Repository and assign a role or custom fields.
  • 7.  RE: known endpoints
    Posted Aug 01, 2024 11:24 AM
    thanks Carson,
    the customer has a PSK SSID and MAC-AUTH (allow ALL MAC-AUTH method) , this is because of limitations on clients (can't do 802.1x).
    I suggested doing STATIC host list but they like the idea of seeing the endpoint and allowing them on by clicking known from a default status of unknown.
    I said not ideal but yes it should work providing known endpoint cleanup interval is set to 0 and we have a policy to disallow "unknown" endpoints and allow "known".
    cheers
    Pete
  • 8.  RE: known endpoints
    Posted Aug 01, 2024 11:30 AM
    Hi Peter,
    I would strongly suggest you use the guest device repository and then you will be able to create custom forms to allow or disallow devices. It is a lot more user friendly and reliable. I would auto register the devices in the repository and add an allow feature / blacklist feature.
  • 9.  RE: known endpoints
    Posted Aug 01, 2024 11:50 AM
    thanks Ben,
    definitely worth a look.
    cheers
    Peter
  • 10.  RE: known endpoints
    Posted Aug 01, 2024 11:59 AM
    Dynamic updates of the Endpoint?  Go for it.
    Requiring the user/admin to go in and edit the Endpoint?  Don't do that.  Use the device repository.
  • 11.  RE: known endpoints
    Posted Aug 01, 2024 12:00 PM
    And never use a static host list, use the device repository.
