L2 and L3 deployment.
  • 1.  L2 and L3 deployment.
    Posted Oct 31, 2014 10:48 AM
    What is the difference between L2 deployment and L3 deployment in controller ?
  • 2.  RE: L2 and L3 deployment.
    Posted Oct 31, 2014 11:09 AM
    Layer 2 means the user gateways are upstream in a switch/router and the controller is dot1q trunked (or access if single VLANs) to the upstream switch.
    Layer 3 means the controller holds the L3 gateways and usually routing is in use.
    Layer 2 is the most popular design.
  • 3.  RE: L2 and L3 deployment.
    Posted Oct 31, 2014 11:16 AM
    Does they makes difference in authentication proccess?
  • 4.  RE: L2 and L3 deployment.
    Posted Oct 31, 2014 11:17 AM
    No, not really. It's more about traffic flow.
  • 5.  RE: L2 and L3 deployment.
    Posted Oct 31, 2014 11:29 AM
    Please give me some more points about this.
