L2 GRE keepalive
  • 1.  L2 GRE keepalive
    MVP
    Posted Jul 23, 2014 08:55 AM
    Doing some testing with layer 2 tunnels and runnign into an issue.
    I've configured the following
    configure terminal
    	interface tunnel 1
            description "naar edge"
            tunnel source 192.168.253.1
            tunnel mode gre 0
            tunnel destination 11.11.11.1
            trusted
            mtu 1400
            tunnel vlan 252
    		no shutdown
    configure terminal
    	interface tunnel 1
            description "naar main"
            tunnel source 11.11.11.1
            tunnel mode gre 0
            tunnel destination 192.168.253.1
            trusted
            mtu 1400
            tunnel vlan 252
     where both .1 addresses are vrrp addresses.
    This works fine but as soon as I enable keepalives on the tunnel interface everything stops working.
    For some reason the keepalives fail 100% of the time, even in a lab environment where everything is directly connected with eachother.
    Anybody got an idea why? If the tunnel is up and passing trraffic, howcome the keepalives don't get through?
  • 2.  RE: L2 GRE keepalive
    Posted Jul 23, 2014 09:55 AM
    What version of ArubaOS is this?
  • 3.  RE: L2 GRE keepalive
    MVP
    Posted Jul 23, 2014 09:57 AM
    vrrp master 6.3.1.8 to vrrp master 6.1.3.7
    Enabling it only on the 6.3.1.8 master was enough to break to tunnel.
  • 4.  RE: L2 GRE keepalive
    Posted Jul 23, 2014 10:04 AM
    6.3.1.9 fixes that, OR disable keepalives.
  • 5.  RE: L2 GRE keepalive
    MVP
    Posted Jul 23, 2014 10:06 AM
    Thanks, didn't catch that bug..  runnign without keepalive at the moment so case closed.
