L2 GRE tunnel with different tunnel vlan at each side
  • 1.  L2 GRE tunnel with different tunnel vlan at each side
    Posted Sep 12, 2013 08:24 AM
    is it possible to have a l2 gre tunnel between two controllers (AOS 6.3.0.0) with different tunnel vlans on each side (within the meaning of a access vlan).
    I found this thread and it sounds that it should work but I'm unable to get that up and running.
    We have two locations A (HQ) and B (remote) and in each location a controller is installed (ctrl-a, ctrl-b). There is a l2 gre tunnel and vlan 1000 at ctrl-b should be 'mapped' to vlan 10 at ctrl-a.
    Configuration of ctrl-a:
    interface tunnel 100
            description "Tunnel Interface"
            tunnel source 10.0.0.10
            tunnel mode gre 0
            tunnel destination 11.1.1.11
            trusted
            tunnel vlan 10
    show interface tunnel 100 of ctrl-a
    Tunnel 100 is up line protocol is up
    Description: Tunnel Interface
    Source  10.0.0.10
    Destination 11.1.1.11
    Tunnel mtu is set to 1100
    Tunnel is a Layer2 GRE TUNNEL
    Tunnel is Trusted
    Inter Tunnel Flooding is enabled
    Tunnel keepalive is disabled
    tunnel vlan 10
    Configuration of ctrl-b:
            tunnel source 11.1.1.11
            tunnel mode gre 0
            tunnel destination 10.0.0.10
            trusted
            tunnel vlan 1000
    show interface tunnel 100 of ctrl-b
    Source  11.1.1.11
    Destination 10.0.0.10
    Tunnel is Trusted
    tunnel vlan 1000
    Everthing is fine when using the same vlan everywhere:
    client: vlan 1000 ---- ctrl-b: tunnel vlan 1000 ---- cltr-a: tunnel vlan 1000 and g1/0 trunk including vlan 1000 ---- switch: trunk including vlan 1000
    Everthing is fine when vlan 'mapping' will be done between ctrl-a and the switch:
    client: vlan 1000 ---- ctrl-b: tunnel vlan 1000 ---- cltr-a: tunnel vlan 1000 and g1/0 access vlan 1000 ---- switch: access vlan 10
    Client can't work if different tunnel vlans are used:
    client: vlan 1000 ---- ctrl-b: tunnel vlan 1000 ---- cltr-a: tunnel vlan 10 and g1/0 trunk including vlan 10 ---- switch: trunk including vlan 10
    Is there a trick or any other suggestions?
    Thanks. Frank
  • 2.  RE: L2 GRE tunnel with different tunnel vlan at each side
    Posted Sep 12, 2013 12:22 PM
    Hi Frank,
    We can see that the tunnel is up from what you've posted so something else isn't quite right.
    Can you let us know what the IP/subnet is for ctrl-a VLAN 10 and ctrl-b VLAN 1000 on the controllers?
    Also how are you using VLAN 10 on ctrl-a
    Can you ping from ctrl-a to the IP assigned to VLAN 1000 on ctrl-b? (assuming there is one)
    Cheers
    James
  • 3.  RE: L2 GRE tunnel with different tunnel vlan at each side
    Posted Sep 13, 2013 09:10 AM
    Hello James,
    controllers are in l2 mode, so no ip addresses are configured for vlan 10 and 1000 so far.
    We are using external DHCP server and router for vlan 10.
    I have added ip addresses from the same subnet (ctrl-a/vlan10 = 10.1.1.1/24, ctrl-b/vlan1000 = 10.1.1.2/24) but I can't ping each other.
    I will strip down our configuration to a minimum in our lab and I will keep you posted.
    Frank
  • 4.  RE: L2 GRE tunnel with different tunnel vlan at each side
    Posted Sep 16, 2013 07:49 AM
    I have build up two controller in our lab from scratch ('write erase all') with only a small (loopback, vlan and tunnel) configuration.
    You can see the lab setup in the chart lab-tunnel-vlan-setup.pdf (I have changed vlan and tunnel numbers, sorry for that).
    I'm unable to ping from ctrl-a vlan 3 to ctrl-b vlan2.
    I'm able to ping from ctrl-a vlan 2 to ctrl-b vlan2.
    You can find some more informations in the pdf (lab-tunnel-vlan-log.pdf).
    I have tested it with AOS 6.2.1.2, too, with the same results.
    If I assume that this configuration is supported, it looks like a bug.
    Do you agree or do you have any other suggestions?
    Frank
    Attachment(s)
    pdf
    lab-tunnel-vlan-setup.pdf   177 KB 1 version
    pdf
    lab-tunnel-vlan-log.pdf   231 KB 1 version
  • 5.  RE: L2 GRE tunnel with different tunnel vlan at each side
    Posted Jul 14, 2016 10:15 AM
    Hello Dears,
    Just wondering if someone could configure it successfully, with 2 different Access VLANs at both ends?
    Thanks.
  • 6.  RE: L2 GRE tunnel with different tunnel vlan at each side
    Posted Jul 20, 2016 10:16 AM
    I don't believe this is possible as even when you only have 1 VLAN through a tunnel the VLAN tag is used. There is no concept of untagged (access) traffic through a GRE tunnel.
    This means both ends must match VLAN numbers.
