L3 controller with Local Captive Portal
  • 1.  L3 controller with Local Captive Portal
    Posted Apr 25, 2017 10:37 PM
    I have a controller configured for Layer3 in that it will host the L2/L3 for several networks and use a single uplink and default route to reach the rest of the network.
    I am having issues with Guest Redirect if I place the VAP on one of these L3 networks. The Guest gets an IP but never gets redirected to the local Captive Portal (using the controllers captive portal).
    If I move the VAP to the VLAN configured for the uplink, it works fine.
    Not sure what I am doing wrong.
    Trunk interface - Only VLAN 1 allowed
    VLAN 1 - 10.10.10.10 (Controllers IP)
    IP ROUTE 0.0.0.0 0.0.0.0 10.10.10.1
    VLAN 20 - 10.20.20.20
    Operstate UP
    Return paths are created in the infrastructure. I can ping 10.20.20.20 with no issues. I can  even stand up DHCP in the infrastructure for VLAN 20 and it will offer an IP to the client.
    VAP on VLAN 20 - Captive Portal Redirect does not work
    CAP on VLAN 1 - Client gets redirected without issue.
    Help?
  • 2.  RE: L3 controller with Local Captive Portal
  • 3.  RE: L3 controller with Local Captive Portal
    Posted Apr 25, 2017 11:02 PM
    I did every search imaginable on the forumn and did not come across that. Thanks! It did the trick!!
