Creating 2 VC's will cause the client to drop when leaving one mobility domain.
If the client reconnects back, they should be getting the same DHCP configuration from the target VC, since you're leaving all the VLANs and configuration the same.
To simplify your config, the SSID has to appear on all VCs, it just
shouldn't be on the same VLAN...
Any network traffic on the same VLAN is L2 traffic.
To answer your initial question, yes, your VC config appears to good.
