I have two stacked switch cat 3850 act as my core network switch
ip routing between vlans is enabled and routing between them and to Internet is working fine
now I have another network on core hp switch 2910 al
Network address 172.16.30.0 /24
What I need :
need to reach this network from my core cisco switch from any vlan and the same in HP need to reach all my core switch network using L3 routing port link between the two switches
What I configure in my Cisco core switches to implement that
#ip routing // enable routing is done and route vlans correctly
#ip route 172.16.30.0 255.255.255.0 10.10.99.2 // add a static route to hp network using next hop (hp ports 23 -25 which should act as l3 ports with ip 10.10.99.2 mask 255.255.255.252)
#interface range give 1/0/1, giving 2/0/1 // ports in the two cisco switches which should connected to hp switch
#no switchport // l3 ports now
#switchport channel-protocol lacp
#switch group 1 mode active
#no shutdown
// link the two ports as an etherchannel coz I have two stacked switched
#interface po1
#no switchport// interface act as l3 #interface po1
#ip address 10.10.99.1 255.255.255.252 // assign ip address for the interface
no shutdown
Problem:
now I want to implement the same in hp switch and i'm not familiar to hp switches what the Configration will be on it
main points in hp Configration
1- create ether channel in ports 23 -24 which connected to cisco core ether channel
2- make this ports in the the etherchannel and the etherchannel act as l3 interface ( the no switch port command on cisco )
3- assign ip address 10.10.99.2 mask 255.255 255.252 to this ether channel interface
4- no shutdown for this interface
5- enable ip routing in the switch ( ip routing command in Cisco switches )
6- add a static route in hp switch to reach cisco networks
( ip route x.x.x.x x.x x x 10.10 99.1)
(ip route z.z.z.z z.z.z.z 10.10.99.1)
7- test that every thing is working fine
#routing#l3switch#LACP#Networking#cisco#HP
