LACP configuration values - which are required config entries
  • 1.  LACP configuration values - which are required config entries
    Posted May 01, 2017 11:00 AM
    I am trying to understand how to configure LACP between my company’s Aruba controllers and wired network switches, and have a few questions.
    The ArubaOS 6.4 user guide says that the following values are used when configuring LACP on a group of ports.
    • LACP Group—The link aggregation group (LAG) number; range is 0 to 7
    • Mode—Active negotiation state or not in an active negotiation state indicated by the passive
    • Priority—The port priority value; range is 1 to 65535 Default 255
    • Timeout—Time out value for the LACP session; Long, the default, is 90 seconds; short is 3 seconds
    As I understand it the first two values: (LACP Group & Mode) are defined manually when adding LACP the ports you wish to include in a LAG.
    Example:
    # Config t
    # interface gigabitethernet 1/0
       lacp group 0 mode active
    # write mem
    # exit
    The second two values: (Priority & Timeout) have a range of values that can be set, but also have defined default values.
    Question:
    Am I required to manually configure the Priority and Timeout values when I configure the ports, or is it acceptable to just add the single line lacp group and mode line to each interface?
    …If so my config would look like this:  (where no Priority and Timeout Values are seen in the config)
    interface gigbitethernet 1/0
    description "GE1/0"
    trusted vlan 1-4094
    interface gigbitethernet 1/1
    description "GE1/1"
    trusted vlan 1-4094
  • 2.  RE: LACP configuration values - which are required config entries
    Posted May 02, 2017 04:07 AM
    This should be fine. you dont need to change priority/timeout values unless they are required to be changed for some reason.
  • 3.  RE: LACP configuration values - which are required config entries
    Posted May 02, 2017 11:59 AM
    I appreciate the help I'm new to LACP and have seen several differing configurations that have me a little confused. Some are slightly different than the config I have suggested above and I'm wondering if they are wrong or if they represent a different type of config that I should consider.  Are any of the additional configurations shown below also correct?... and if so why are they so different?
    A.)
        description "GE1/0"
        trusted vlan 1-4094
        lacp group 1 mode active
        description "GE1/1"
        trusted vlan 1-4094
    B.)
    interface port-channel 1
            trusted
            trusted vlan 1-4094
            switchport access vlan 3
            description "GE1/0"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet 1/1
            description "GE1/1"
            trusted
            trusted vlan 1-4094
    C.)
            add gigabitethernet 1/0
            add gigabitethernet 1/1
            trusted
            trusted vlan 1-4094
            description "GE1/0"
            trusted
            trusted vlan 1-4094
            description "GE1/1"
            trusted
            trusted vlan 1-4094
    I am also looking for clairification on the LACP configuration values below so I can explain them to my wired networking team:
    1.) Priority: The port priority value; range is 1 to 65535 Default 255 (The higher the value number the lower the priority)
            Q:  Can you explain what this value does and explain why I would change it to something other that its defaul setting?
    2.) Timeout—Time:  amount of time that a port-channel interface waits for a LACPDU from the remote system before terminating the LACP session.  Values: Default = Long and is 90 seconds; short is 3 seconds
             Q:  Can you explain a circumstance where I might want to set this value to short instead of the default.
