Lacp doesn't allow the traffic between Aruba and juniper switches
  • 1.  Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 03:42 AM
    Hello All,
    I am trying to test the bond config and verify its redundancy . However my check fails so far. Bond status shows up on both sides
    When I ping from PC1 src 192.168.0.1 to PC2 dst 192.168.0.2 , it fails both ways
    PC1-->access VLAN 2 port ge0/0/0--> Aruba Sw---LACP:Trunk mode--->Juniper switch---> access VLAN 2  Ge0/0/0-> PC2
    Config in Juniper switch:
    interfaces {
    ge-0/0/0 {
    unit 0 {
    family ethernet-switching {
    port-mode access;
    vlan {
    members test;
    ge-0/0/1 {
    unit 0 {
    port-mode access;
    vlan {
    members test;
    ae0 {
    aggregated-ether-options {
    minimum-links 1;
    link-speed 1g;
    lacp {
    active;
    periodic fast;
    unit 0 {
    port-mode trunk;
    vlan {
    members all;
    vlans {
    test {
    vlan-id 2;
    root@juniper-lab# run show interfaces ae0 extensive
    Physical interface: ae0, Enabled, Physical link is Up
    Interface index: 128, SNMP ifIndex: 555, Generation: 131
    Link-level type: Ethernet, MTU: 1514, Speed: 2Gbps, BPDU Error: None, MAC-REWRITE Error: None, Loopback: Disabled, Source filtering: Disabled, Flow control: Disabled,
    Minimum links needed: 1, Minimum bandwidth needed: 0
    Device flags : Present Running
    Interface flags: SNMP-Traps Internal: 0x4000
    Current address: 5c:5e:ab:6a:52:c3, Hardware address: 5c:5e:ab:6a:52:c3
    Last flapped : 2020-04-29 09:28:06 UTC (04:44:28 ago)
    Statistics last cleared: Never
    Traffic statistics:
    Input bytes : 5579951 3032 bps
    Output bytes : 4823259 2048 bps
    Input packets: 43739 3 pps
    Output packets: 36351 2 pps
    IPv6 transit statistics:
    Input bytes : 0
    Output bytes : 0
    Input packets: 0
    Output packets: 0
    Input errors:
    Errors: 0, Drops: 0, Framing errors: 0, Runts: 0, Giants: 0, Policed discards: 0, Resource errors: 0
    Output errors:
    Carrier transitions: 6, Errors: 0, Drops: 0, MTU errors: 0, Resource errors: 0
    Logical interface ae0.0 (Index 65) (SNMP ifIndex 557) (Generation 130)
    Flags: Up SNMP-Traps 0x40004000 Encapsulation: ENET2
    Statistics Packets pps Bytes bps
    Bundle:
    Input : 8607 0 1034913 0
    Output: 24 0 2340 0
    Adaptive Statistics:
    Adaptive Adjusts: 0
    Adaptive Scans : 0
    Adaptive Updates: 0
    Link:
    ge-0/0/10.0
    ge-0/0/11.0
    LACP info: Role System System Port Port Port
    priority identifier priority number key
    ge-0/0/10.0 Actor 127 5c:5e:ab:6a:52:c0 127 1 1
    ge-0/0/10.0 Partner 32768 00:1a:1e:1a:c7:40 255 11 1
    ge-0/0/11.0 Actor 127 5c:5e:ab:6a:52:c0 127 2 1
    ge-0/0/11.0 Partner 32768 00:1a:1e:1a:c7:40 255 12 1
    LACP Statistics: LACP Rx LACP Tx Unknown Rx Illegal Rx
    ge-0/0/10.0 17105 17060 0 0
    ge-0/0/11.0 17104 17059 0 0
    Marker Statistics: Marker Rx Resp Tx Unknown Rx Illegal Rx
    ge-0/0/10.0 0 0 0 0
    ge-0/0/11.0 0 0 0 0
    Protocol eth-switch, Generation: 147, Route table: 0
    Flags: Is-Primary, Trunk-Mode
    root@juniper-lab> show route
    inet.0: 3 destinations, 3 routes (3 active, 0 holddown, 0 hidden)
    + = Active Route, - = Last Active, * = Both
    0.0.0.0/0 *[Static/5] 05:12:38
    > to 192.168.2.1 via me0.0
    192.168.2.0/24 *[Direct/0] 05:12:38
    > via me0.0
    192.168.2.50/32 *[Local/0] 05:12:38
    Local via me0.0
    Aruba Switch config :
    (aruba-lab) #show vlan
    VLAN CONFIGURATION
    VLAN Description Ports
    1 VLAN0001 GE0/0/1-9 GE0/0/12-47 GE0/1/0-1 Pc0
    2 test GE0/0/0 GE0/0/16 Pc0
    (aruba-lab) #show trunk
    Trunk Port Table
    Port Vlans Allowed Vlans Active Native Vlan
    GE0/0/16 ALL 1-2 1
    Pc0 ALL 1-2 1
    (aruba-lab) #show interface port-channel 0
    port-channel 0 is administratively Up, Link is Up, Line protocol is Up
    Hardware is Port-Channel, LACP enabled, Address is 00:1a:1e:1a:c7:40
    Description: Link Aggregate
    Member port(s):
    GE0/0/10 is administratively Up, Link is Up, Line protocol is Up
    GE0/0/11 is administratively Up, Link is Up, Line protocol is Up
    Speed: 2 Gbps
    Interface index: 1441
    MTU 1514 bytes
    Flags: Trunk, Trusted
    Link status last changed: 0d 04h:22m:44s ago
    Last clearing of counters: 0d 04h:22m:44s ago
    Statistics:
    Received 33499 frames, 4445555 octets
    0 pps, 2.040 Kbps
    435 broadcasts, 0 runts, 0 giants, 0 throttles
    0 error octets, 0 CRC frames
    33064 multicast, 0 unicast
    Transmitted 40393 frames, 5154835 octets
    1 pps, 2.694 Kbps
    235 broadcasts, 0 throttles
    0 errors octets, 0 deferred
    0 collisions, 0 late collisions
    GE0/0/10:
    Statistics:
    Received 16838 frames, 2235957 octets
    0 pps, 1.020 Kbps
    308 broadcasts, 0 runts, 0 giants, 0 throttles
    16530 multicast, 0 unicast
    Transmitted 24466 frames, 3089783 octets
    1 pps, 1.674 Kbps
    186 broadcasts, 0 throttles
    GE0/0/11:
    Statistics:
    Received 16661 frames, 2209598 octets
    0 pps, 1.020 Kbps
    127 broadcasts, 0 runts, 0 giants, 0 throttles
    16534 multicast, 0 unicast
    Transmitted 15927 frames, 2065052 octets
    0 pps, 1.020 Kbps
    49 broadcasts, 0 throttles
    (aruba-lab) # show lacp 0 internal
    Flags: S - Device is requesting slow LACPDUs
    F - Device is requesting fast LACPDUs
    A - Device is in Active mode P - Device is in Passive mode
    LACP Internal Table
    Port Flags Pri AdminKey OperKey State Num Status
    GE0/0/10 FP 255 0x1 0x1 0x3e 0xb up
    GE0/0/11 FP 255 0x1 0x1 0x3e 0xc up
    (aruba-lab) # show lacp 0 counters
    LACP Counter Table
    Port LACPDUTx LACPDURx MrkrTx MrkrRx MrkrRspTx MrkrRspRx ErrPktRx
    GE0/0/10 15839 15793 0 0 0 0 0
    GE0/0/11 15836 15790 0 0 0 0 0
    (aruba-lab) # show lacp 0 neighbor
    LACP Neighbor Table
    Port Flags Pri OperKey State Num Dev Id
    GE0/0/10 FA 127 0x1 0x3f 0x1 5c:5e:ab:6a:52:c0
    GE0/0/11 FA 127 0x1 0x3f 0x2 5c:5e:ab:6a:52:c0
    (aruba-lab) #show running-config
    Building Configuration...
    # Configuration file for ArubaOS
    # ArubaOS Version 7.4.0.4 54198
    version 7.4
    interface-profile switching-profile "test"
    access-vlan 2
    interface-profile switching-profile "trunk-all"
    switchport-mode trunk
    interface-profile switching-profile "trunk-ports"
    interface-profile tunneled-node-profile "default"
    interface-profile poe-profile "default"
    interface-profile poe-profile "poe-factory-initial"
    enable
    interface-profile enet-link-profile "default"
    interface-profile lacp-profile "lacp1"
    group-id 0
    timeout short
    interface-profile lldp-profile "default"
    interface-profile lldp-profile "lldp-factory-initial"
    lldp transmit
    lldp receive
    med enable
    interface-profile mstp-profile "default"
    interface-profile pvst-port-profile "default"
    vlan-profile dhcp-snooping-profile "default"
    vlan-profile mld-snooping-profile "default"
    vlan-profile igmp-snooping-profile "default"
    snooping
    vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
    snooping
    spanning-tree
    mode mstp
    gvrp
    mstp
    lacp
    vlan "1"
    vlan "2"
    description "test"
    interface gigabitethernet "0/0/0"
    interface gigabitethernet "0/0/5"
    interface gigabitethernet "0/0/10"
    interface gigabitethernet "0/0/11"
    interface gigabitethernet "0/0/16"
    interface vlan "1"
    interface vlan "2"
    ip address 192.168.0.60 255.255.255.0
    interface mgmt
    ip address 192.168.2.60 255.255.255.0
    interface port-channel "0"
    enet-link-profile pc_default
    (aruba-lab) #show ip route
    Codes: C - connected
    O - OSPF, O(IA) - OSPF inter area
    O(E1) - OSPF external type 1, O(E2) - OSPF external type 2
    O(N1) - OSPF NSSA type 1, O(N2) - OSPF NSSA type 2
    M - mgmt, S - static, * - candidate default
    D - DHCP
    Gateway of last resort is 192.168.2.1 to network 0.0.0.0 at cost 0
    S * 0.0.0.0 /0 [0] via 192.168.2.1
    C 192.168.0.0/24 is directly connected: vlan2
    C 192.168.0.60/32 is directly connected: vlan2
    M 192.168.2.0/24 is directly connected: mgmt
    M 192.168.2.60/32 is directly connected: mgmt
    Any ideas what am I missing here ?
  • 2.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    MVP GURU
    Posted May 28, 2020 05:48 AM
    Apparently the LACP is working correctly; On both ends the bonds (Link Aggregations) are well formed and the communication between them looks good to me: physical links are Up, BPDU are flowing and nothing is being blocked.
    If I were you I will point the finger against the VLAN memberships (especially on the ArubaOS side)...it's not clear to me - I admit I'm not an expert neither on Aruba MAS nor on Juniper Switches - if VLAN memberships are matching on both aggregated interfaces or not (I see VLAN ID 2 but I'm not sure how it is tagged on the Aruba MAS side).
    What is the Native VLAN ID (PVID) on each logical aggregated interface (I would say that that VLAN ID gets "untagged")?
    What are the permitted VLAN IDs on each logical aggregated interface (I would say that those VLAN IDs get "tagged")?
  • 3.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 07:21 AM
    In your Aruba MAS switches, you didn't specify the allowed vlans on your trunk
    You should add "trunk allowed vlan <VLAN_ID>"  command
  • 4.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 07:52 AM
    I allowed all , I am not sure why it wouldn't show up on the running config
    But when I run show trunks I see it for port channel 0
    GE0/0/16 ALL 1-2 1
    Pc0 ALL 1-2 1
  • 5.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 09:11 AM
    Did you check the mac-address table to make sure layer 2 connectivity is ok? Are you learning the mac-address on the right ports?
    show mac-address-table vlan 2
    Do you have by any chance firewall turned on the devices you are testing from?
  • 6.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 11:03 AM
    Thanks for your swift response .
    (aruba-lab) #show mac-address-table vlan 2
    Total MAC address: 2
    Learnt: 2, Static: 0, Auth: 0, Phone: 0, Sticky: 0
    MAC Address Table
    MAC Address Address Type VLAN Interface
    98:5a:eb:e2:22:9e Learned 0002 Pc0
    a0:1e:0b:05:0b:0b Learned 0002 GE0/0/0
    Ethernet adapter Ethernet:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
    Physical Address. . . . . . . . . : A0-1E-0B-05-0B-0B
    DHCP Enabled. . . . . . . . . . . : No
    Autoconfiguration Enabled . . . . : Yes
    Link-local IPv6 Address . . . . . : fe80::b083:3801:4eb5:6b4b%11(Preferred)
    IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . :
    DHCPv6 IAID . . . . . . . . . . . : 195042827
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-EE-5C-5C-A0-1E-0B-05-0B-0B
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    NetBIOS over Tcpip. . . . . . . . : Enabled
  • 7.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 11:12 AM
    Even in juniper switch it knows where to forward
    PC interface
    en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV>
    ether 98:5a:eb:e2:22:9e
    inet6 fe80::c2e:c452:ea33:f26f%en0 prefixlen 64 secured scopeid 0x7
    inet 192.168.0.1 netmask 0xffffff00 broadcast 192.168.0.255
    nd6 options=201<PERFORMNUD,DAD>
    media: autoselect (1000baseT <full-duplex,flow-control>)
    status: active
    root@juniper-lab# run show ethernet-switching table
    Ethernet-switching table: 3 entries, 2 learned, 0 persistent entries
    VLAN MAC address Type Age Interfaces
    test * Flood - All-members
    test 98:5a:eb:e2:22:9e Learn 0 ge-0/0/0.0
    test a0:1e:0b:05:0b:0b Learn 57 ae0.0
  • 8.  RE: Lacp doesn't allow the traffic between Aruba and juniper switches
    Posted May 28, 2020 12:34 PM
    Can you verify the ARP table on the PCs using arp -a? Does PC1 learn the mac of PC2? Does PC2 learn the mac of PC1?
    Are you sure there is no firewall on the PCs?
