LACP on 6000 controller
  • 1.  LACP on 6000 controller
    Posted Jan 23, 2014 08:30 AM
    Hi all, I am having an issue trying to set up LACP on 2 x 6000 controllers. They are on 6.1 firmware.
    They are currently running on a single 10G fibre to an an alcatel 6900 VC stack.  All I want to do is add an additional 10G port LACP. Have done this before with no issues but no joy with these boxes, any ideas ?
  • 2.  RE: LACP on 6000 controller
    Posted Jan 23, 2014 08:54 AM
    Can you please share you config ? and how do you have it configured on the alcatel side of things ?
    interface gigabitethernet 0/0
            description "GE0/0"
            trusted
            trusted vlan 1-4095
            switchport mode trunk
            lacp group 1 mode active
    interface gigabitethernet 0/1
            description "GE0/1"
            trusted
            trusted vlan 1-4095
    interface port-channel 1
            trusted
            trusted vlan 1-4095
    (HOME-MASTER-CONTROLLER) # show  lacp 1 neighbor
    Flags: S - Device is requesting slow LACPDUs
           F - Device is requesting fast LACPDUs
           A - Device is in Active mode P - Device is in Passive mode
    LACP Neighbor Table
    Port    Flags  Pri    OperKey  State  Num    Dev Id
    GE 0/0  SA     32768  0x1      0x3d   0x102  00:23:AC:08:EF:00
    GE 0/1  SA     32768  0x1      0x3d   0x103  00:23:AC:08:EF:00
  • 3.  RE: LACP on 6000 controller
    Posted Jan 23, 2014 09:27 AM
    Victor, I have configured the controller via the Gui, its a trunk lacp with 4 x vlans,1 default and 3 802.1q. Im happy i have this correct but have had to revert it back to a single link as it failed.  As for the 6900 end I am familliar with this kit, soset up a dynamic lacp as below
    linkagg lacp agg 2 size 2 admin-state enable
    linkagg lacp agg 2 actor admin-key 2
    linkagg lacp port 1/1/15 actor admin-key 2
    linkagg lacp port 2/1/15 actor admin-key 2
    I firstly had this working for maybe 30 secs then one port would go down, after a firmware upgrade I cannot get it towork at all.
    thanks
  • 4.  RE: LACP on 6000 controller
    Posted Jan 23, 2014 09:56 AM
    What AOS version do you have installed ?
    WHen you get a chance please share your config on the Aruba side
    Also have you tried passive on controller side and active on the Alcatel side
