LACP on AP 515 in Aruba OS 8
This thread has been viewed 22 times
  • 1.  LACP on AP 515 in Aruba OS 8
    Posted Apr 30, 2019 05:10 AM
    we have 2 controllers in a cluster under my mobility Master. Now we have some new AP515 and we want to use lacp port channel for the ap 515 wired connection.
    Where can I confiure the lacp port channel for the APs?
    I cannot find this option in my mobility master profiles...
  • 2.  RE: LACP on AP 515 in Aruba OS 8
    Posted Apr 30, 2019 05:29 AM
    From page 362 of the ArubaOS 8.4 user guide:
    Striping LMS IP can no longer be used to stripe the traffic as each AP has GRE tunnels to more than one managed device. Therefore, starting from ArubaOS 8.2.0.0, Cluster LACP is used to stripe traffic on a per-UAC basis. That is, in a cluster setup, the clients or users on the same AP are steered to different UACs and the traffic is striped to these UACs.
    When cluster is enabled, striping IP is not used even if it is a single-node cluster; the striping of traffic for the
    Ethernet interfaces is according to the UAC node.
    For a non-cluster setup, the striping LMS IP is used in the same way as before.
    For an upstream traffic, the cluster LACP load-balances these UACs across the Ethernet ports.
    For a downstream traffic, because the Source-IP and MAC address of the GRE packets are different from those of AP, the AP's uplink switch spreads the traffic.
    To configure AP LACP using CLI:
    On an uplink switch of an AP, use the following command to configure LACP between the two ethernet ports of the AP:
    (host) [md] (config) #ap-lacp-striping-ip
    (host) [md] (AP LACP LMS map information) #aplacp-enable
    (host) [md] (AP LACP LMS map information) #striping-ip 10.15.127.2 lms 10.15.127.3
    To view the configuration, execute the following command:
    (host) #show ap-lacp-striping-ip
    Parameter Value
    AP LACP Striping IP Enabled
    GRE Striping IP 10.15.127.2 LMS 10.15.127.3
    The lms-ip value in ap-system-profile will be used as a key to look up entries in ap-lacp profile.
  • 3.  RE: LACP on AP 515 in Aruba OS 8
    Posted May 02, 2019 04:14 AM
    we have a controller cluster with 2 aruba 7210 controllers. We just want to use both ethernet ports on the ap.
    Should we use both port on th ap without a lacp port-channel?
    thanks
  • 4.  RE: LACP on AP 515 in Aruba OS 8
    Posted May 02, 2019 07:51 AM
    Leon,
    It depends what you are trying to accomplish.  If this is not about an AP-515, please open another forum thread.
  • 5.  RE: LACP on AP 515 in Aruba OS 8
    Posted May 02, 2019 07:53 AM
    But it's about the ap 515. We just want to increase the bandwidth?
  • 6.  RE: LACP on AP 515 in Aruba OS 8
    Posted May 02, 2019 08:36 AM
    Understood.  You would configure LACP.
