I use CLI Snippet to enable LACP trunks between switches but the problem is the configuration is dropped on the next config update from Central.
Any way to manage LACP trunks directly in Central ?
Many thanks.
Hi Franck,
CLI Snippets should be used to push configuration not available in UI. Configuration pushed via CLI Snippets will be overridden by values mentioned in UI
The other option is to make use of template groups.
this does not answer or even address the question.
I'm afraid you need to use template groups to configure LACP in Central.
