LAG/LACP on Outdoor 375 & 377 using Copper SFP
  • 1.  LAG/LACP on Outdoor 375 & 377 using Copper SFP
    Posted Jun 26, 2018 02:57 PM
    I am using the 370 series APs and want to plug in 2 cables to the AP.  As there is a GbE copper port and an SFP port, I wanted to put the other cable into the SFP port and turn on lacp ("lacp enable").
    Two questions with this:
    1. Is there an SFP that will work for copper GbE in this instance? The ordering guide only includes fiber ones
    2. Will LAG/LACP work on these two ports in this fashion? I would imagine so, but just want to confirm.
    Thanks!!
    From the ordering guide:
    - Q8N52A SFP-LX Extended Temperature 1000BASE-LX SFP 1310nm LC Connector Pluggable GbE XCVR
    - Q8N53A SFP-SX Extended Temperature 1000BASE-SX SFP 850nm LC Connector Pluggable GbE XCVR
    - And the Q8N54A strain relief/connector gland kit which should be purchased in tandem.
  • 2.  RE: LAG/LACP on Outdoor 375 & 377 using Copper SFP
    Posted Jun 27, 2018 10:41 AM
    Does someone from Aruba know if LAG/LACP will work between the two ports on a 370-series AP?
    If so, are there recommended copper 1GbE SFP's for these?
  • 3.  RE: LAG/LACP on Outdoor 375 & 377 using Copper SFP
    Posted Nov 12, 2018 06:23 PM
    Hi RYH
    From 8.3 it is supported.
  • 4.  RE: LAG/LACP on Outdoor 375 & 377 using Copper SFP
    Posted Nov 13, 2018 11:08 PM
    Note there are no copper GBICs for the 37x or 318 APs. Only the extended range Single and Multimode fiber.
