Lan extension
  • 1.  Lan extension
    Posted Nov 29, 2013 04:58 AM
    Hello guys,
    i would know if exist a guide to implement the LAN extension.
    i have a controller that have two VLAN:
    1) VlAN 1 (MANAGEMENT address).
    2) VlAN 20 (for this vlan the controller doesn't have an address)
    The controller have two interfaces linked to a switch, fa1/7 (in access on VLAN 20)
    and fa1/6 (in accesso on VLAN 1).
    I want to propagate by a RAP the VLAN 20, and if i connect to rap's SSID, the controller links me to the switch in Layer 2.
    So is like if i am directly connected to my LAN without routing, and i recive an ip by my external dhcp, and the controller works like a L2 switch.
    is it possible?
    if it is, there is a particular configuration?
    Best regards
    Andrea
  • 2.  RE: Lan extension
    Posted Nov 29, 2013 07:42 AM
    Entirely possible and very simple.
    Just create your VAP with whatever other settings you want, and associate it with VLAN 20.
  • 3.  RE: Lan extension
    Posted Dec 04, 2013 09:13 AM
    OK now it works!
  • 4.  RE: Lan extension
    Posted Dec 06, 2013 06:49 PM
    hi,
    i have tried connect to ethernet port of RAP, but i don't receive any ip.
    how can i assign the same Vlan to ethernet port of RAP?
    thanks in advance
    Best regards
  • 5.  RE: Lan extension
    Posted Dec 06, 2013 08:49 PM
    Under AP> Ethernet Interface Port X configuration> Wired AP, you need to enable it, and put in the VLAN that you want wired devices on.
  • 6.  RE: Lan extension
    Posted Dec 09, 2013 03:50 AM
    the correct  path is: wizard>Under AP> Ethernet Interface Port X configuration> Wired AP?
  • 7.  RE: Lan extension
    Posted Dec 09, 2013 05:15 AM
    Perfect, very easy.
    Thank you, now all works fine.
    Best regards
