Ok, this is looking promising. I can ping our Radius server on our corp LAN from the remote local controller. That ping is success from vlan xxx which is the vlan that the WAP's get their dhcp addresses from (as they are plugged into ports on the local which are in vlan access xxx mode). I also have a VLAN xxy and a matching dhcp server pool set up on the local to provide address for wireless clients however as of now that vlan interface is "up/down" as no physical interfaces are assigned to that vlan. What is the proper config (which interface can I assign to be in VLAN xxy) in order to bring vlan xxy to "up/up" status?
I do not think I want to put the WAPs VLAN (xxx) ports into trunk mode and include vlan xxy there, right? Do I place the port that hosts the WAN IP/VLAN into trunk mode and include vlan xxy there?
rif
