Landing Page after 802.1x authentication
  • 1.  Landing Page after 802.1x authentication
    Posted May 24, 2017 10:52 AM
    we just deployed a new SSID for BYOD.
    It works with 802.1x EAP-PEAP authentication.
    Everything fine so far.
    Is it possible to redirect a user to a landing page after successfull 802.1x authentication?
    We have very restricted access for BYOD and the user should know that. We would like to inform the user with a landing page after authentication.
  • 2.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 11:01 AM
    Yes, it would just be tied to the user-role.
  • 3.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 11:21 AM
    So, I could define a user Role with a Landing page behind?
  • 4.  RE: Landing Page after 802.1x authentication
    How can I make it?
  • 5.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 11:23 AM
    Create a captive portal profile and assign it to the user-role.
  • 6.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 01:23 PM
    OK,
    Do I have to assign the user role to the AAA profile as well? We also have PEF-NG license.
    Is it "Initial role" or "802.1x authentication role" in tha AAA profile?
    The Landing Page should appear after successfull 802.1x authentication. I don't want to use captive portal for 802.1x authentication. The Landing Page should open after authentication, just for informing the user.
  • 7.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 01:33 PM
    Yes, you would assign it as the default 802.1X role.
  • 8.  RE: Landing Page after 802.1x authentication
    Posted May 24, 2017 04:32 PM
    OK,
    Thanks a lot! I will try.
    Great Community!
  • 9.  RE: Landing Page after 802.1x authentication
    Posted May 29, 2017 04:18 AM
    Something seems not working correct.
    After successfull authentication, nothing happens. Browser does not open, no landing page.
    - I set up a new user role with reference to the captive portal profile.
    - In the AAA-Profile (802.1X Authentication Default Role) I assign the user role.
    Did I forget something?
  • 10.  RE: Landing Page after 802.1x authentication
    Posted May 29, 2017 05:31 AM
    I just read an older article, descriped that the User VLAN also requires an IP interface on the controller...
    That's not configuret at the moment.
    But I think there is no need to configure an IP interface when redirecting to a completley external page?
    Is it correct?
  • 11.  RE: Landing Page after 802.1x authentication
    Posted May 29, 2017 01:20 PM
    In order for the redirect to work you need an IP address assign to the vlan the user will land on
    Get Outlook for iOS
