Laptop cannot connect to 5Ghz channel 140
  • 1.  Laptop cannot connect to 5Ghz channel 140
    Posted Jan 07, 2020 09:47 AM
    Hi, our surface tablet cannot connect to 5 ghz on channel 140 and 144. We are using a  Aruba 7210 controller and AP315.
    It's working for other type of laptop and other channels for the surface.
    It's also did some test with a IAP on those channels and it works.
    So what could I be doing on the controller that certain channels are not seen by the surface pro ?
    The surface is using a Marvell Avastar. Microsoft support just had me update to the latest driver with no effect.
    Any ideas would be appreciated.
  • 2.  RE: Laptop cannot connect to 5Ghz channel 140
    MVP EXPERT
    Posted Jan 07, 2020 10:09 AM
    If you are certain that the device does not the channels in question, then you can remove them from the Regulatory Domain Profile.
    show ap regulatory-domain-profile
    I've personally not had any exposure to the Marvell Avastar chipset, so cannot confirm the supported channels. A packet capture of the association conversation would provide us with the supported channel list.
  • 3.  RE: Laptop cannot connect to 5Ghz channel 140
    Posted Jan 07, 2020 11:00 AM
    Do you see the bssid on those channels?
    You can use a windows tool like WinFi lite to see a complete list of all bssid's in range.
  • 4.  RE: Laptop cannot connect to 5Ghz channel 140
    MVP EXPERT
    Posted Jan 07, 2020 12:57 PM
    Channel 144 is not supported on most surfaces (except of the Pro6). When using channelbonding 40mhz channels channel 144 is aggeregated with channel 140 and therefore dont can be used to.
    See the excelent database create by Mike Albano that do a create work on this.
    https://clients.mikealbano.com/
  • 5.  RE: Laptop cannot connect to 5Ghz channel 140
    Posted Jan 07, 2020 01:41 PM
    Why would a particular channel not be supported on a particular device? Driver issue, hardware restriction?
  • 6.  RE: Laptop cannot connect to 5Ghz channel 140
    MVP EXPERT
    Posted Jan 07, 2020 01:42 PM
    Its a hardware restricions of the wirelles chipset used in your Surface.
    More info:
    https://lizardsystems.com/wi-fi-scanner/articles/80211ac-144-channel-support/
