Laptop Certificate to connect?
  • 1.  Laptop Certificate to connect?
    Posted May 27, 2016 06:46 PM
    If we have IA225s, how do we setup certificates to rollout for approved laptops to connect to wifi? Is there a certificate per user or a general certificate I'd have to deploy? Can't seem to find the feature in the latest version on IA225s. Thanks ahead of time for assistance.
  • 2.  RE: Laptop Certificate to connect?
    Posted May 27, 2016 06:47 PM
    That's a pretty big project that needs to be designed and deployed
    carefully. Have you reached out to your Aruba partner?
  • 3.  RE: Laptop Certificate to connect?
    Posted May 30, 2016 03:30 PM
    Can you provide high level guidance for where in ia225 interface do you find the certificate authentication part? I can take it from there just need the pointers.
  • 4.  RE: Laptop Certificate to connect?
  • 5.  RE: Laptop Certificate to connect?
    Posted May 31, 2016 04:10 PM
    I see password and radius settings - already familiar with that as we're using RADIUS - but not where you setup certificates for laptops. Am I completely missing something here?
  • 6.  RE: Laptop Certificate to connect?
    Posted May 31, 2016 04:28 PM
    That would all be done on your RADIUS server.
