Laptops connecting on 20MHz at slow speeds
  • 1.  Laptops connecting on 20MHz at slow speeds
    Posted Nov 15, 2019 01:58 PM
    I'm having a problem where some devices are connecting on Client PHY: n 20 MHz and running at very slow speeds. Other devices are connecting upon ac 80MHz and receiving much fast connection speeds. Would this be a laptop problem or controller setup issue? Below is what I receive when running the show AP association client-mac.
    PHY Details: HT : High throughput; 20: 20MHz; 40: 40MHz; t: turbo-rates (256-QAM)
    VHT : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
    <n>ss: <n> spatial streams
    Association Table
    Name bssid mac auth assoc aid l-int essid vlan-id tunnel-id phy assoc . time num assoc Flags Band steer moves (T/S) phy_cap
     Stats
    Parameter Value
    Channel 132
    Channel Frame Retry Rate(%) 2
    Channel Frame Low Speed Rate(%) 0
    Channel Frame Non Unicast Rate(%) 42
    Channel Frame Fragmentation Rate(%) 0
    Channel Frame Error Rate(%) 0
    Channel Bandwidth Rate(kbps) 1944
    Channel Noise 92
    Client Frame Retry Rate(%) 3
    Client Frame Low Speed Rate(%) 0
    Client Frame Non Unicast Rate(%) 0
    Client Frame Fragmentation Rate(%) 0
    Client Frame Receive Error Rate(%) 0
    Client Bandwidth Rate(kbps) 1298
    Client Tx Packets 424139
    Client Rx Packets 310499
    Client Tx Bytes 45428428
    Client Rx Bytes 398323111
    Client SNR 53
    A2c_SM SeqNum, Old SeqNums 174 0
  • 2.  RE: Laptops connecting on 20MHz at slow speeds
    Posted Nov 15, 2019 02:46 PM
    What band are those devices connecting on?  They could have 2.4ghz single-stream only wireless adapters, which might explain their issues.
  • 3.  RE: Laptops connecting on 20MHz at slow speeds
    Posted Nov 15, 2019 03:46 PM
    I have several of the same Dell laptops connected on the network and some
    of them connect up only on 2.4 and others connect on 5 utilizing the AC 80
    MHz bandwidth at faster speeds. Currently, this device is connecting on the
    2.4 GHz but it does have 5 GHz capability. They are Dell 3390 2in1 devices.
    *Adam Moore*, CNA 6.5
    Network+ Certified
    Network Manager
    Delano Union School District
    661-721-5000 ext. 00135
    amoore@duesd.org
  • 4.  RE: Laptops connecting on 20MHz at slow speeds
    Posted Nov 15, 2019 04:54 PM
    Ultimately, the laptop decides what access point and what band it connects to.  We can influence it to connect to 5ghz by making sure that the 5ghz transmit power on the access point is 6 db higher than the 2.4ghz band.
