Large Aruba RAP to replace switch
  • 1.  Large Aruba RAP to replace switch
    Posted Jan 26, 2018 04:35 PM
    Hello! At the moment for some small offsides we use a RAP to make a tunnel back to our controller then run a switch off it to get more wired connections. Does switch a thing as a RAP switch exist? An aruba switch which can tunnel back to a controller like a RAP just without the access point?
  • 2.  RE: Large Aruba RAP to replace switch
    Posted Jan 27, 2018 09:37 AM
    Probably need to make use of the ArubaOS-swith per port tunnel node or per user tunnel node.
    If you search through this forum for per port tunnel node. I'm sure you'll find something
  • 3.  RE: Large Aruba RAP to replace switch
    Posted Jan 27, 2018 03:25 PM
    Thanks that really helpful, this is exactly what I was looking for but would it be suitable to run over the Internet? I can see it’s a GRE tunnel so can I use IPSec like a RAP to secure the traffic?
