Layer-2 GRE to Controller
  • 1.  Layer-2 GRE to Controller
    Posted Aug 13, 2019 02:22 AM
    Hello everyone,,
    I'd like to create a layer-2 gre tunnel to our aruba controller to bridge a vlan to a remote site.  The controller configuration seems straightforward, I set the tunnel destination as the VC address of the IAP cluster, enter the vlan I'd like to bridge, select mode L2, Protocol 1.
    I'm stuck on configuring the IAP end.  The only fields I have are "Host", "GRE type" and "Per-AP Tunnel".  This is in AirWave btw.
    I've tried entering the IP of the controller, or the VRRP of the cluster, but I never see any GRE traffic at the controller.  I'm also not sure how to specify which VLANs would be encapsulated from the IAP side.
    Any pointers appreciated.  Thanks,..
