Layer 2 mobility
  • 1.  Layer 2 mobility
    Posted Jul 01, 2016 06:49 AM
    Hi all,
    If a customer has layer 2 mobililty enabled, with 2 local controllers, both on the same VLAN, and a user associates with 1 of the controllers, does the other controller know about the association in case the user roams, or would it just be the local they associated to?
    Jamie.
  • 2.  RE: Layer 2 mobility
    Posted Jul 01, 2016 07:09 AM
    If layer 2 mobility is enabled on the controller the user is roaming to, that second controller will look at its' bridge table to see what VLAN to put the user in.  You can see the bridge table on a controller by typing "show datapath bridge table"
  • 3.  RE: Layer 2 mobility
    Posted Oct 14, 2017 05:46 AM
    This is very interesting Colin Joseph, I am reading about how to enable layer 2 mobility and I simply coundn't find anything !
    Please, do you have a guide about how to do that, we have controllers that are connected across layer 2 yet still layer 2 mobility doesn't work in our envirnment.
    Appreciate your answer.
  • 4.  RE: Layer 2 mobility
    Posted Oct 14, 2017 10:31 AM
    It is in the Virtual AP profile.
