Layer 2 tunnel between AP and controller
  • 1.  Layer 2 tunnel between AP and controller
    Posted Jul 12, 2015 07:42 AM
    Hi guys,
    I have a centralized Wi-Fi gateway and I want to tunnel the user traffic from remote locations to it (layer 2 tunneling). The remote locations are connected to the centralized datacenter over a layer 3 network. As I understand from Aruba documentation, I have three options to achieve such deployment:
    1- Using Aruba IAP and configure a IPsec/L2TP tunnel to a centralized controller, then deliver the layer 2 trafic to the Wi-Fi gateway ==> I don't want to use this option because the controller is not managing the IAP, it is acting as VPN termination and I need to be able to manage the deployed AP
    2- Using RAP ==> I can't go with that because I want to deploy Indoor and outdoor APs on the remote locations
    3- Using  local controllers on  remote locations and a master controller on the centralized datacenter then create a layer 2 GRE tunnels between the local and the master controllers
    My question is: If going with the third option, can I manage the APs and the SSIDs deployed on remote locations through the centralized master controller ?
    Thank you guys in advance for your help!
  • 2.  RE: Layer 2 tunnel between AP and controller
    Posted Jul 12, 2015 07:44 AM
    You can do RAP with outdoor APS. That is your best option.
