layer 3 roaming with clearpass server. the best firmware version for instant ap105?
  • 1.  layer 3 roaming with clearpass server. the best firmware version for instant ap105?
    Posted Nov 26, 2015 06:55 AM
    I am running ap 105 clusters
    the users and ap's are on separate vlans per cluster
    authentication and external portal are provided via a clearpass server
    I am having issues where the layer 3 roaming is not working although all subnets/vlans are entered in the ap105 config
    Which firmware is advised as the best to use for this type of setup?
  • 2.  RE: layer 3 roaming with clearpass server. the best firmware version for instant ap105?
    Posted Dec 27, 2015 01:05 PM
    there aren't firmwares specific for certain goals. in general it seems the latest Instant version is the best. until some issue is found, then it is the next.
