Layer 3 VLAN Interface at Controller level or cluster level for controllers?
This thread has been viewed 32 times
  • 1.  Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 10 days ago
    Hello, I'm in the process of setting up 8.10 to convert from 6.5.   Do I set the L3 VLAN IP's at each controller, or can I set it at the cluster level?  We're a small shop, so only two mobility conductors and two controllers in a cluster.
  • 2.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 9 days ago
    Bueller?
  • 3.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 9 days ago
    VLAN IPs are typically set on the controller level, because each controller needs to have it's own IP address per VLAN to avoid IP address conflicts.
  • 4.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 9 days ago
    Thank you!!   Do you know if a document is posted somewhere to tell me best practices for where to assign policies?  Its a bit confusing coming from 6.5
  • 5.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    MVP
    Posted 9 days ago
    The SE from yuor Aruba account team should be able to assist.
    In AOS 8 most all the configuration is in an inherited tree structure under . Managed Network. It is recommended to put no configuration directly there.
    AirGroup configuration is a special case. I do not recall where that configuration goes.  We took that opportunity to totallt redesign our configuration from scratch.
    am assuming a Mobility Condictor instead of Primary / Secondary controllers.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 6.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 9 days ago
    This documentation may help in better understanding and getting best-practices.
