Layer 3 VLAN Interface at Controller level or cluster level for controllers?
This thread has been viewed 32 times
  • 1.  Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 13 days ago
    Hello, I'm in the process of setting up 8.10 to convert from 6.5.   Do I set the L3 VLAN IP's at each controller, or can I set it at the cluster level?  We're a small shop, so only two mobility conductors and two controllers in a cluster.
  • 2.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 12 days ago
    Bueller?
  • 3.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 12 days ago
    VLAN IPs are typically set on the controller level, because each controller needs to have it's own IP address per VLAN to avoid IP address conflicts.
  • 4.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 12 days ago
    Thank you!!   Do you know if a document is posted somewhere to tell me best practices for where to assign policies?  Its a bit confusing coming from 6.5
  • 5.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    MVP
    Posted 11 days ago
    The SE from yuor Aruba account team should be able to assist.
    In AOS 8 most all the configuration is in an inherited tree structure under . Managed Network. It is recommended to put no configuration directly there.
    AirGroup configuration is a special case. I do not recall where that configuration goes.  We took that opportunity to totallt redesign our configuration from scratch.
    am assuming a Mobility Condictor instead of Primary / Secondary controllers.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 6.  RE: Layer 3 VLAN Interface at Controller level or cluster level for controllers?
    Posted 11 days ago
    This documentation may help in better understanding and getting best-practices.
