LB monitor so if a CPPM server status is not OK it will be excluded from pool
  • 1.  LB monitor so if a CPPM server status is not OK it will be excluded from pool
    Posted Oct 15, 2017 08:24 AM
    Hi Guys,
    I want to change the LB monitor so if a CPPM server status is not OK it will be excluded from pool, to avoid problems like we had last week. I found API explorer for guest but not for CPPM, can you help find such URL - that will respond with the server real status and not just https request.
    Please advise,
    Asa
  • 2.  RE: LB monitor so if a CPPM server status is not OK it will be excluded from pool
    Posted Oct 15, 2017 01:59 PM
    What would be "status ok" in your scenario?
  • 3.  RE: LB monitor so if a CPPM server status is not OK it will be excluded from pool
    Posted Oct 15, 2017 03:57 PM
    I suggest you utilize a RADIUS HC, such that if the authN fails you then mark the node as down/out-of-service.
