ldap
  • 1.  ldap
    Posted Apr 25, 2012 08:08 AM
    I am having VBN configured. with ldap authentication.
    when i Checked the LDAP auth  from controller It was working.
    then the clients from remote site also got authenticated.They are using the wired as well as wifi from RAP.
    but now  I hav checked on controller but in  AAA test server it shows server out of service.
    on cli  server status   it shows " admin bound  NO"   but i think no changes are made on controller .
    now whos is authenticating those remote clients ?  cache on RAP ?
    also  controller > clients. it shows aaa status pending.  is it due to unavailability of ldap server ?
    setting initial role in 802.1 x profile to authenticated means with if ldap auth fails still the clients can connect to that ssid/port
  • 2.  RE: ldap
    Posted Apr 25, 2012 02:14 PM
    Are you using encryption or captive portal?
  • 3.  RE: ldap
    Posted Apr 25, 2012 02:18 PM
    no captive portal
    WPA2 AES
  • 4.  RE: ldap
    Posted Apr 25, 2012 02:25 PM
    The LDAP server might have been taken out of service because it is or was unreachable at some time.  Go back into the LDAP server definition and disable, then enable it and see if it works.
