last person joined: 11 hours ago
LDAP Auth => Aruba650 w/6.1.3.8 to MS 2008R2
  • 1.  LDAP Auth => Aruba650 w/6.1.3.8 to MS 2008R2
    Posted Aug 26, 2013 08:18 PM
    Greetings, I realize that there have probably been a thousand threads on this. Having problems getting Aruba 650 controller to do LDAP auth against a Microsoft 2008R2 AD environment. Keep getting error as follows:
    " authmgr[1580]: <199802> |authmgr| ldapclient.c, ldap_auth_api:124: Invalid authentication protocol 4 for LDAP"
    Any help would be greatly appreciated.
  • 2.  RE: LDAP Auth => Aruba650 w/6.1.3.8 to MS 2008R2
    Posted Aug 26, 2013 08:24 PM
    Is this for captive portal authentication?
    Change your authentication type to PAP under the Captive Portal Authentication Profile.
  • 3.  RE: LDAP Auth => Aruba650 w/6.1.3.8 to MS 2008R2
    Posted Aug 27, 2013 04:28 AM
    At this point, just trying to get the server provision under Authentication / Servers / LDAP and then tested under Diagnostics.
    UPDATE!!!! -- Got it!  -- I had the base DN incorrect.  When I brought it up a level and issued the query user command as referenced in the article you posted, it worked.  Validated I was using the wrong OU for the test user.  Once fixed, works like a champ!
    THANKS!
    --MJT
  • 4.  RE: LDAP Auth => Aruba650 w/6.1.3.8 to MS 2008R2
    Posted Aug 27, 2013 12:04 AM
    Please see the article here:  https://arubanetworkskb.secure.force.com/pkb/articles/Troubleshooting/R-41 for an LDAP configuration and troubleshooting example.
