Network Management
LDAP Authentication to Airwave Questions
  • 1.  LDAP Authentication to Airwave Questions
    Posted Aug 07, 2018 02:57 PM
    1. Is it possible to have both RADIUS and LDAP Authentication working on the same Airwave server?
    2. Is LDAPS (LDAP over SSL) supported?
    3. Can you use a different port (636 instead of 389) for LDAPS?
    Thanks.
    Neil
  • 2.  RE: LDAP Authentication to Airwave Questions
    Posted Aug 07, 2018 11:08 PM
    1) Yes, you can do multiple remote access servers.  The order will be RADIUS:TACACS:LDAP:LocalDB when remote auth is preferred.  Known feature request to allow choosing the order, not enough customer interest to push it beyond the Product team.
    2) Yes, LDAP-S is supported, with option to validate server certs.
    3) Yes, you can choose different port.
    This is all controlled from the AMP Setup -> Authentication tab.
  • 3.  RE: LDAP Authentication to Airwave Questions
    Posted Aug 16, 2018 03:53 PM
    Here is the solution I worked out with TAC.
    1. You can only have ONE authentication method enabled at a time.
      So I had to Disable RADIUS authentication because I wanted to use LDAP. I was hoping to use both because our Network team prefers using RADIUS to authenticate, but our Help Desk uses LDAP.
    2. You must use LDAP with start-tls or clear-text authentication.
      If I try to use ldap-s the AMP server doesn't even initiate any outbound traffic to the LDAP server.
    3. You must use the fully qualified BIND DN name. user@ldapserver.com doesn't work.
    4. Make sure the account .you are logging  in with is in the right search DN.
    That's it. Everything is working now (except for RADIUS authentication).
    -Neil
