LDAP can not authenticate when connect to SSID
  • 1.  LDAP can not authenticate when connect to SSID
    Posted Jun 02, 2019 09:05 PM
    when we try to make AAA authentication from controller its working fine.
    when user try to connect to SSID that require a LDAP authentication , after make user/pass  it canot authenticate or get ip address.
    here is the show auth trachbuf | mac add
    show auth show auth-tracebuf | oinclude 5thFloorAP 88:10:8f:df:d8:e8
    Jun 2 14:09:57 client-finish -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - -
    Jun 2 14:09:57 server-finish <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 15616
    Jun 2 14:09:57 server-finish-ack -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - -
    Jun 2 14:09:57 inner-eap-id-req <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 8960
    Jun 2 14:09:57 inner-eap-id-resp -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - - user@domain.com
    Jun 2 14:09:57 eap-gtc-token-req <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 13056
    Jun 2 14:09:57 eap-gtc-token-res -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 11
    Jun 2 14:09:57 pap-request -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - - user@domain.com
    Jun 2 14:09:57 station-down * 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0 - -
    Jun 2 14:09:57 pap-response <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/HQDCO - - user@domain.com
    Jun 2 14:09:57 eap-tlv-rslt-failure <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 11008
    Jun 2 14:09:57 eap-failure <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 4
    Jun 2 14:10:00 station-up * 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0 - - wpa2 aes
    Jun 2 14:10:00 station-term-start * 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0 78 -
    Jun 2 14:10:00 client-finish -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - -
    Jun 2 14:10:00 server-finish <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 15616
    Jun 2 14:10:00 server-finish-ack -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - -
    Jun 2 14:10:00 inner-eap-id-req <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 8960
    Jun 2 14:10:00 inner-eap-id-resp -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - - user@domain.com
    Jun 2 14:10:00 eap-gtc-token-req <- 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 13056
    Jun 2 14:10:00 eap-gtc-token-res -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - 11
    Jun 2 14:10:00 pap-request -> 88:10:8f:df:d8:e8 48:4a:e9:6f:41:c0/test - - user@domain.com
    i can see this
  • 2.  RE: LDAP can not authenticate when connect to SSID
    note that this is VMC version 8.4
  • 3.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 02, 2019 10:14 PM
    Did you enable EAP Termination?
    Did you install the EAP-GTC supplicant on the device?
    Does the device trust the controller's internal certificate?
    To be honest, EAP-Terminaton, PEAP with LDAP is not really recommended.  A legitimate radius server is recommended.
  • 4.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 03, 2019 03:27 PM
    yes enable in profile
    yes
    we have test with trust and without trust but not help
    i havenot raduis server in the network
    i have asked TAC if the LDAP-AD has any kind of limitation and not recomndadtion but he told me no its easy and no issue while intergration with it .
    this is a dot1x profile configuration
    (Aruba-VMC) *[mynode] #show aaa authentication dot1x test
    802.1X Authentication Profile "test"
    Parameter Value
    Max authentication failures 0
    Interval between Identity Requests 5 sec
    Quiet Period after Failed Authentication 30 sec
    Reauthentication Interval 86400 sec
    Use Server provided Reauthentication Interval Disabled
    Use the termination-action attribute from the Server Disabled
    Multicast Key Rotation Time Interval 1800 sec
    Unicast Key Rotation Time Interval 900 sec
    Authentication Server Retry Interval 5 sec
    Authentication Server Retry Count 3
    Framed MTU 1100 bytes
    Max number of requests sent during an Auth attempt 5
    Max Number of Reauthentication Attempts 3
    Maximum number of times Held State can be bypassed 0
    Dynamic WEP Key Message Retry Count 1
    Dynamic WEP Key Size 128 bits
    Interval between WPA/WPA2/WPA3 Key Messages 1000 msec
    Delay between EAP-Success and WPA2/WPA3 Unicast Key Exchange 0 msec
    --More-- (q) quit (u) pageup (/) search (n) repeat Delay between WPA/WPA2/WPA3 Unicast Key and Group Key Exchange 0 msec
    Time interval after which the PMKSA will be deleted 8 hr(s)
    Delete Keycache upon user deletion Disabled
    WPA/WPA2/WPA3 Key Message Retry Count 3
    Multicast Key Rotation Disabled
    Unicast Key Rotation Disabled
    Reauthentication Disabled
    Opportunistic Key Caching Enabled
    Validate PMKID Enabled
    Use Session Key Disabled
    Use Static Key Disabled
    xSec MTU 1300 bytes
    Termination Enabled
    Termination EAP-Type eap-peap
    Termination Inner EAP-Type eap-gtc
    Enforce Suite-B 128 bit or more security level Authentication Disabled
    Enforce Suite-B 192 bit security level Authentication Disabled
    Token Caching Disabled
    Token Caching Period 24 hr(s)
    CA-Certificate N/A
    Server-Certificate default
    TLS Guest Access Disabled
    Ignore EAPOL-START after authentication Disabled
    --More-- (q) quit (u) pageup (/) search (n) repeat Handle EAPOL-Logoff Disabled
    Ignore EAP ID during negotiation. Disabled
    WPA-Fast-Handover Disabled
    Check certificate common name against AAA server Enabled
  • 5.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 03, 2019 03:34 PM
    You should try using it with a mobile device, because the restrictions are less.  Either way, EAP-Termination with LDAP is not the way to go and the EAP-GTC shim software has not been updated in years, so I would not proceed with that.
    If you have Active Directory, a free version of NPS exists in every Windows sever.
  • 6.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 03, 2019 03:45 PM
    yes i have test with mobile many times but same issue
    connection time-out after write a user name and password
    and from auth tracbuf there and error rap-faliure and i dont see any one face this error and all documntation explain the basic configuration that i have attached.
    and TAC doesnot hepl me in this error
  • 7.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 03, 2019 09:07 PM
    TAC probably doesn't know what to do, because nobody uses LDAP anymore for encrypted SSIDs.  There are no Windows Clients for GTC and the GTC shim that we had on our website has not been updated for years.  Please look into standing up a Windows NPS server (radius).
    https://community.arubanetworks.com/aruba/attachments/aruba/115/6113/1/Using+Microsoft+Windows+2008+Server+With+Aruba.pdf
  • 8.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 06, 2019 06:27 PM
     did you mean that no one use LDAP with Arbva controller version 8 .
    no customer has this soultion any more ?
  • 9.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 06, 2019 07:13 PM
    I mean that very few customers use this solution, because everyone with a Windows Server has can deploy a radius server for free.  Also, LDAP+GTC requires that a supplicant be installed on all Windows devices.
  • 10.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 15, 2019 12:08 AM
    i have try after download GTC from aruba web site but not help.
  • 11.  RE: LDAP can not authenticate when connect to SSID
    Posted Jun 15, 2019 01:20 AM
    What did you try?
  • 12.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 03:49 PM
    try to install GTC Plugin from aruba site to machine windows but not help and same erreo "Eap fealiure"
  • 13.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 04:10 PM
    The EAP-GTC plugin has not been updated for years and it will not be updtated.  There could be a bug in it.  A better option is to use radius, instead.
  • 14.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 04:59 PM
    we have not raduis and i need documnation from aruba that aruba controller not recommnded LDAP AD
  • 15.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 05:03 PM
    If you have AD, each Microsoft Windows server comes with a free radius server.
    The EAP-GTC software is not scalable because you would have to install it on every Windows computer and configure it manually.  There are also no software updates for it.  You also cannot use machine authentation with EAP-GTC.  EAP-GTC is not something that Aruba created; Aruba made the software to help users who had a ldap server and could not do 802.1x with radius.  With every microsoft server having a built in radius server, it is no longer necessary.
  • 16.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 05:09 PM
    we havanot any problem to install and configure maunely the GTC in each machine , but we try in in some machine but not working
  • 17.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 05:13 PM
    Right.  The EAP-GTC software is not updated or supported, so you should use Radius, instead.
  • 18.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 05:21 PM
    if we hav not raduis , we can not make intergrated with LDAP-AD. right ?
  • 19.  RE: LDAP can not authenticate when connect to SSID
    Posted Jul 03, 2019 07:20 PM
    Not without EAP-GTC.
